1000 Modifications This section is specifically for questions and advice pertaining to mods of the current 1000 models.
I need sprocket help....Please help
Old Sep 11, 2009 | 06:46 PM
RaceIt454's Avatar
Default I need sprocket help....Please help
Hey guys I had my 08 1000rr now for a while and im looking for more low end power. I only have a 2bros pipe on it and think i should change the sprockets around. Is this a good way to get the kind of power i want? Again i am looking for more power at low range, and I think the sprocket change should do it. My question is what sprockets do you change for this and by how much? I know nothing about changing the sprockets, I just know of guys doing it for different kinds of power.
Thanks for your help!
Jake
Old Sep 11, 2009 | 07:13 PM
wellarmedCr@cker's Avatar
Yeah, sprokets will help. You running a power commander with your slip on? Go to http://www.rogueracing.org/gearing.htm for help on gearing.
Old Sep 11, 2009 | 07:18 PM
GP Paul's Avatar
I haven't changed anything on my 1000, but I have found that more than -1 tooth on the front will make highway speeds uncomfortable on previous bikes.
Also, while a smaller front sprocket may wear faster, at least you won't need to add links on the chain as opposed to adding teeth to the rear.
Old Sep 12, 2009 | 09:34 AM
RaceIt454's Avatar
Yea could you just buy links for the chain or would you have to buy a new, longer chain? And no I just have the slip on and thats it
Old Sep 12, 2009 | 11:53 AM
chainstretcher's Avatar
Admin Emeritus & MVN
It's always a good idea to replace sprockets and chains as a set. You can find some decent deals on ebay for a set. Just make sure it includes an RK or DID chain and not some cheesy Chinese chain
Old Sep 13, 2009 | 09:28 PM
Sprock's Avatar
1 down on front, two or three up on rear is usually enough to give ya the punch you
are looking for...........and as mentioned ..........a quality chain
She'll be higher rpm when running steady out on the highway though ..that's the con
Old Oct 8, 2009 | 04:01 AM
perf0rmance's Avatar
Jake
just to clarify
changing sprocket doesn't generate any extra power.. it just changes how it's delivered. Your BUTT will feel the difference, and that difference is in how it accelerates.
just be aware that your speedometer and odometer will have a larger %error when you do this. to alleviate this effect, get a speedohealer.
Old Oct 8, 2009 | 05:50 AM
abeer1's Avatar
Why would you want to change the gearing on a 1K? I can understand on a 600, but a 1k should have plenty in stock format.
Old Oct 8, 2009 | 09:57 AM
johnnyx's Avatar
That's an argument you don't want to start, my friend. If 1k's were enough power for everybody in stock format, nobody would make sprockets, exhausts, carbs, chains, power commanders, ignition timers, etc etc etc for them.
Old Oct 8, 2009 | 10:02 AM
johnnyx's Avatar
YOU MUST REPLACE YOUR CHAIN AND SPROCKETS AS A SET. It's in the freakin' manual.
And with all the money you're spending on that kit (that you don't need, assuming yoru current setup is not worn), you can just buy a PC and get an ACTUAL hp boost, not just a fake one that only feels like more hp at the expense of gas milage and engine wear (nearly double in some circumstances). After that, get the race manifold for your exhaust. Slip-ons are really for sound only, the hp boost is minimal as you're still not letting any more air pass through the engine. Hell 1 or 2 of the ~5 hp boost you get form a slipon is purely from the weight loss. Sprocket swapping is like the last thing you do when you've done everything else, and still just aren't happy with things. It doesn't add power, it just makes your front sprocket spin faster sooner, thus sending more power to the rear wheel early on. This does, of course, mean you're cruising at like 7k, which I've never gotten used to.
