Alternator Dampner Gone Bye Bye
Hi All,
Bike wont start, starter kicks over, just not turning the engine over, compression test, no compression
Battery - brand new
Spark - Tested all 4 and O.K.
Fuel - Getting through
Valves - all within spec
Jump starts and runs perfect, is my conclusion correct?
Aussie Johnno
Battery - brand new
Aussie Johnno
If you mean you jumped it successfully with another battery and the starter worked, then it's not the damper
If you could push start it and it ran, then it probably is the damper
Not the end of the world to fit a new one, or rebuild your old one.
See earlier posts
www.mrcycles.com for a new one
See earlier posts
Just an update
Got it all apart and it looks like my damper imploded on itself, there were chunks of fibrous material all over the place.
Mine only had 9 plates, only three were fibre.
going to but a new one $210.00AU.
I do not think it is worth trying to re build or replace with a second hand one.
It was quite an easy job though except for the alternator bolts
Aussie Johnno
Aussie Johnno
hmm
08-28-2013 07:21 AM
